03-23-2025 02:54 PM
Solved! Go to Solution.
04-13-2025 10:42 AM - edited 04-15-2025 06:55 AM
Thumbs up, bro! I bought this mouse cuz it is ROG. Asus provides premium products, but it looks like their software and devices are trash and not worth + We literally have no answer about fix... So support is dog******, sadly.
03-23-2025 08:18 PM
Hello,
Sorry that you are experiencing these issues, and I can assure you that none of this is being done on purpose!
As it seems from the previous post mentioned, new firmware was implemented to solve your issues, so please check that your mouse and receiver firmware are both up to date on Armoury Crate, and if the issue persists, please provide me with your mouse firmware version so I can look into this further for you.
03-31-2025 11:31 AM
Any news? Or it's easier to do a refund cuz this connection loss issue can happen 1-3 times in an hour...
03-31-2025 06:37 PM
Please provide your mouse firmware inside Armoury Crate with a screenshot so I can look into this further for you.
04-01-2025 03:50 AM
Here is the armory crate update tab
04-01-2025 11:14 PM
Please refer to this website to download and install the manual firmware updater and see if this solves your issue.
04-02-2025 04:39 AM
Thanks for responce. I updated and fully charged the mouse. I hope it'll help. Will report if the issue is not fixed.
04-07-2025 05:13 AM
2 days after the installation, it was okay. Now, I have the same issue again.
03-27-2025 04:06 PM
I have the same issue with the last update. Updating was a mistake... Can we somehow bring back the previous firmware?
04-03-2025 09:29 PM
@Crux1ebasketball stars wrote:I have the same issue with the last update. Updating was a mistake... Can we somehow bring back the previous firmware?
That’s really frustrating. ASUS should at least provide a rollback option if firmware updates worsen performance. Have you tried reaching out directly to support?
