I bought my Keris Wireless Aim point for 2 weeks now it has some randomly connecting issue.
I3anker
My mouse act wierd after 1 week of usage it started to have some disconnecting issue.
It disconnect randomly but the led light still go on ,to fix this i have to switch to wired mode and then back to wireless. Does anyone faced the same problem? I wanna fix this real quick.
1 ACCEPTED SOLUTION
Accepted Solutions
I3anker
I have tried reinstall Armoury Crate and the problem seem to be fixed.
I3anker
Nate152
Hello l3anker
Thank you for reporting your problem is solved by reinstalling Armoury Crate.
As a reminder for everyone, when reinstalling Armoury Crate, be sure to use the Armoury Crate uninstall tool first.
