Harpe Ace Mini Excessive Battery Drain
Rotasuu
Recently, I noticed my mouse's battery has been draining very fast. The moment I unplug it after a full charge it starts going down extremely fast.. I'd say down to 70% within 10 minutes? The battery will drain incredibly fast until 55% the draining slows down. It has been stuck on 53% for the longest time with no draining after a gaming session. It seems like armoury crate itself is reading the battery status wrongly. I purchased this mouse last month from Amazon and things were working great until some recent firmware updates.
Currently on Device Version: 1.00.15 and dongle (2.4ghz) version: 7.00.02
I've already configured many settings such as:
  • turning off the RGB
  • uninstalled armoury crate and using armoury crate gear now
  • firmware is up to date on both omnireceiver and the mouse itself
  • Performance are on 1k polling rate since i do not own the booster rate
1 ACCEPTED SOLUTION
Accepted Solutions
Rotasuu
Update: After plugging back in and charging it around 85%, the excessive battery drain stopped so far. I have not seen any more strange behaviors of the battery drain since then.
MasterC
Community Admin
Community Admin
Please report the issue here.
I was unable to replicate this issue.
My firmware versions.
The mouse was fully charged:
After half an hour (see time in bottom-right corner):
After an hour:
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
I guess I will drain my mouse completely and see if I can re-calibrate the mouse. It's been stuck at 53% the whole night after gaming sessions.
Rotasuu
