Gladius III Wireless Aimpoint tracking issues when using Armoury Crate
Yamoima
Hello, I am using ASUS ROG Gladius III Wireless Aimpoint and everything works flawless except tracking on my mouse pad. Sometimes I encounter tracking issues and sometimes I don't. It is so inconsistent. Therefore, I tried resetting the mouse and noticed that the problem is solved when my mouse is not connected to the Armoury Crate. However, when I connect my mouse to the Armoury Crate, the issue occurs again. I think it is a software issue but I am not sure if other people have the same issue as me. I would be happy if someone could help, thanks!
6 REPLIES 6
MasterC
Community Admin
Community Admin
Have you tried selecting the correct mouse surface or calibration in Armoury Crate?
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
Yes, I tried both methods. Unfortunately, they don't seem to fix my issue. Once the mouse drivers are installed, I get tracking issues. On the other hand, when there are no drivers installed the mouse works as intended.
MasterC
Community Admin
Community Admin
Have you tried another PC to verify the same issue occurring?
Yes, I tried it on my desktop and laptop and I had the issue again. Both of them have different mouse pads (They are not ASUS mouse pads though). Recently, I cleaned both mouse pads and I am going to try again. If issue still persists, I will update here.
When in doubt, selecting the default mouse surface should be a safe bet.
Is it better to use default mouse surface option rather than manual calibration? If yes, when should I use manual calibration option?
