01-06-2024 01:38 AM - edited 01-06-2024 04:41 AM
I am gonna go off of the keyboard i have - claymore ii -
Why not have a little indicator light on the caps lock num lock keys like the one we have on the spacebar ?
Its more convenient and makes more sense to look at the caps lock button to see if your caps lock is on.
The bright white LEDs on top for the lock keys are both distracting and not that functional ie. when you lay back you cant see thoıse lights at all, and when you sit straight they are directly in your eye.
You could use the empty space for media keys, which would make x2 times sense in claymore example since the media buttons are absent if you remove the keypad and wanna use it as TKL
