ROG Strix Scope NX Wireless Deluxe-Doesn't turn on system start also sometimes realy laggy wirelles
KLMPLS
I started having a problem where the keyboard doesn't start in USB mode. I have to switch to wireless and back to USB for it to work in USB. I would use wireless only but sometimes it becomes unbelievably laggy.
It's not like it's unusable but it is annoying the USB thing not the laggnes that's terrible.
Nate152
Hello KLMPLS
Do you have the cable and wireless dongle connected directly to pc usb ports? You can use pc case or motherboard usb ports.
For the lag, you can try using the usb extender to see if this helps.
