[ROG Azoth] When will you fix double input issues?
RiptorX
The keyboard itself is great (not the amoury crate software though - that one is quite terrible) for its design, functions, looks, sound and polished feel but to this day I still have double inputs registered on certain keys which makes the keyboard fundamentally flawed. Reseting the keyboard or swapping switches out only fixed the problem temporarily. I have changed the type speed output in the windows keyboard settings of windows 10 several, but to no avail. The keyboard only feels extremly sluggish after.
I have yet to alter my windows registry as suggested in some reddit post concerning that topic but I honestly don't really want to especially since I am also using the keyboard on my working laptop via bluetooth as well. As for my private gaming PC I mostly use the 2,4 gig dongle in close proximity (under the table but only 30 cm or so away) but always experience the issue during cable connected sessions as well.
I thought by now you would have solved this by a software update (the dude suggesting the registry altercation pointed out it is soley a software issue). I would love to try some other triggers such as the NX snow triggers, but there is unfortunately no place to buy them.
Sib3riX
Level 12
I have same problem with 2x azoths. One is DE layout and one is US layout. I saw reddit post with registry fix but that is not permenent fix. Hopefully Asus will fix it. We just need to be boring and keep asking.
Same issue here, also saw the reddit post but it didn't help. DE layout, all keys fine but the space bar. Really annoying.
