Need part numbers for RGB & White LEDs for Strix Flare
beatlemaniac
Hello all!
I have a few RGB LEDs as well as all of the Media LEDs that have gone out on my Strix Flare I bought a few years ago. Does anyone have the part numbers for these items? I'd much rather repair the keyboard myself than spend $100+ for another one.
Thanks,
Steve Hurd
Floyds Knobs, IN
4 REPLIES 4
Nate152
Hi beatlemaniac
Welcome to the ROG forum.
Have you tried resetting your keyboard by holding Fn+ESC keys for 10-15 seconds?
Do you have Armoury Crate installed and fully updated?
Definitely done all that. The white LEDs have been out for at least 2 years and My second keyboard ley has lost its blue led. I was going to just order some replacement parts from Digi-Key and do some surgery on the device.
Have you managed to fixed yours? I have a few keys that lost its blue led as well and the same for the media leds. Looks like a common problem on this keyboard?
Nate152
Unfortunately, this kind of information is hard to come by, you'll probably have to pull a bad one out and research it.
