HELP: ROG Strix Scope II 96 Wireless not working normal
Crasje
Help!
Just installed the keyboard, but then I type it seems to jump to field or icon and not actually type letters.
I also dont see the keyboard under hardware in armoury crate.
Suggestions anyone?
Corsair 3500x
Corsair HX1200i
Asus ROG Maximus Z690 Extreme
Intel Core i9-12.900k
Corsair H150i Elite Elite LCD XT
Corsair DDR5 Dominator Platinum RGB 2x32GB 5600Mhz
Samsung 980 PRO 2TB M.2 SSD (2x)
ROG RTX3080-O10G-Gaming
Monitor 1: ASUS ROG Swift PG34WCDMC
Monitor 2: ROG Swift OLED PG27AQDM
ROG Spatha X
Windows 11
1 ACCEPTED SOLUTION
Accepted Solutions
Crasje
Solved! After correctly running a firmware update, armoury crate found it!
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
Crasje
OK, the keys are now working normal, how do I get into the software of the keyboard?
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
Crasje
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
