Azoth Volume Reset to full problem
JeffLo
anyone having problem with the volume going back to full when you alt tab in and out of a game?
everytime i alt tab from a game the volume goes back up to full then i set it to lets say 50% then alt tab and set the volume to also 50% then if i go back to the game it goes back to full 100% so anoying
Nate152
Hello JeffLo
The ROG Azoth controls the windows volume, once you set it, it shouldn't change.
Is Armoury Crate and your ROG Azoth fully updated?
YES all updated, it changes the volume when it change its profile, it does not remember the volume thats why when i alt tab from game and desktop it changes backj to 100% when i return to game its so anoying everytime i alt tab back to game i have to lower the volume or i dont use profile switching
Nate152
Have you created any scenario profiles in Armoury Crate?
If so, try deleting them and test the volume.
