Asus Rog Claymore II battery charge and discharge issue (Solved)
drbtt
Hi!
I'm having some battery issues that after the lastest firmware, before the update it was working fine. i'll explain:
- im using usbc to usba (3.2) from the back io (asus rog b450-e)
- keyboard firmware: 20.12.01 / 1.00.14 / 1.00.12
When charging it stops incrementing percetage in armoury crate, says "charging" but it keeps randomly stuck at any % until i replug it againg. Same with the keyboard battery level indicator. I tried to drain the battery till 1%, then charging and got stuck at 11% and 90% until i replug the cable.
Once is fully charged it quickly discharges in a few minutes to 90%, it gets stuck a few hours at this point, then drop quickly to 86%. if i recharge again from this point it does quickly but once i unplug the cable, again drops quickly to 90% and 86%. From 86% to 16% seems to be just fine, but at 16% it gets stuck again for a period and then starts dropping normally again.
I did this process 3 times and seems to do the same every time.
i'd like to know is someone is having a similar issue after the lastest firmware or is a faulty battery before make a RMA, but as i metion before, it appeared since the lastest firmware.
Thanks!
22 REPLIES 22
Nate152
neikosr0x
I am having teh same issue, installed the altest firmware and still the same thing... charges to 100% and as soon as i disconnect it, it drops to 81%
patriciojose13
asus ROG claymore ii 2023 - still unsolved.
stuck at 67% even with the latest update.
YNNOxBE
