Asus Azoth - OLED not displaying battery life indicator correctly.
GD2X
I hope the picture displays correctly.
I have bought this new keyboard and it just arrived yesterday, the oled screen is working and currently set to 100%, I can see the spinning rog logo easily but the volume and battery indicators are so faint, I have to put my nose up to the screen to see it.
This can't be right as I have seen it really clearly in review videos. I have tried plugging in a cable and I have tried resetting to the keyboard multiple times, and I can't fix the issue.
7 REPLIES 7
GD2X
I am not sure how to edit the post and the picture did not upload correctly.
Here is a link https://i.imgur.com/TcsrDCu.png
Nate152
Hello GD2X
This seems to be normal as the brightness of the indicators don't change when adjusting the brightness of the OLED display.
But it isn't normal because I can't see the indicators. Not unless I put my nose right up the screen and I can see it faintly.
(I don't know to edit posts on here)
Further more, at 25% brightness, the OLED screen is black. I can only see the spinning asus rog logo at 50% minimum.
Nate152
You must be in a very well it room room.
At 25% brightness, the OLED display is darker than the indicators, but I can still see it.
I picked up another keyboard, and it works flawlessly with none of the issues stated above.
I wish you had been more helpful.
Nate152
Sorry about that, I should have had you test it in a dark room.
But, good to hear all is well with a new keyboard.
