ROG Strix Fusion Wireless auto turn off annoying sound
abadimacharka
Hello guys,
I have ROG Strix Fusion Wireless and it have a feature to auto turn off after some minutes of inactivity, it makes really loud peep it doesn't matter what volume level you already have it will just peep at high volume and give you heart attack.
How to turn this off?
Thanks!
5 REPLIES 5
Nate152
Hello abadimacharka
Could it possibly be a low battery notification?
Does the beep happen when your headset is fully charged?
Hello Nate152,
No it happens when you are not playing any sounds in the system (inactive) for few minutes.
Nate152
It sounds like you are referring to sleep.
The beep could be a notification that it disconnected and went to sleep.
If it's too annoying, you could set it so it doesn't go to sleep or auto turn off.
Exactly but how to do so? I checked in crate and there was no option
Nate152
If there's no option in Armoury Crate,  you may not be able to disable this feature.
 Doing a bit of searching, I haven't found a way to disable the power saving mechanism.
