Rog Delta S Wireless Pairing Problem
Enverhan
Hey there, i have ROG DELTA S WIRELESS
I know basic English.
Yesterday was all good
, today when i turn on headset i just hear beep and blue led blinking 2 time and repeat. I tried pairing tool to pair again but pair button is gray. i tried disable antivirus firewall and etc. that was not solve my problem and after i tried on safety mod and still the same.
2 ACCEPTED SOLUTIONS
Accepted Solutions
same files im downloaded  again and tried but i want to say something i solve my problem with other bat file 😄
how can i explain it idk but note it;
1. tried exe files and again nothing happen
2.update mode.bat after then i saw cmd windows and writen inside begin... just waited and i hear unplug+plug sound
if anyone have same problem just ask him to try this steps.
i dont want to try it for record video but As I just said anyone have same problem ask him to do thats 😄
Sorry for my useless English
i broke it again for you and record it here is the video.
need to headset pc mode before (15 sec func. button)
https://youtu.be/6O9brv2oxmk
still pair is gray not clickable but driver installed and paired pc-headset
Uploaded by Enverhan Uğur on 2025-03-29.
25 REPLIES 25
Nate152
Hello Enverhan
Try using the USB-C to USB-A adapter for the wireless dongle, it's found in the box. Then, connect it to a usb 2.0, 3.0 or 3.1 port, you can use motherboard or pc case usb ports. For good measure, restart your pc after connecting it.
Does this help get your ROG Delta S Wireless connected with 2.4GHz wireless mode? I'm using the USB-C to USB-A adapter with my ROG Delta II and all is good with connectivity.
Still same i tried with adapter on blue usb-a and normal usb-a but not solution for me ( tried on front pc case usbs and back usbs on motherboard)
Nate152
Does your ROG Delta S Wireless show in Device Manager?
If yes, right click on it and click uninstall, then reboot.
After rebooting, try pairing it.
No
Nate152
Ok,
Try this:
1) Connect the charging cable to your headset and pc.
2) Make sure the Mode switch on the headset is set to 2.4GHz.
3) Make sure the wireless dongle is connected to a pc usb port, I'll still recommend to use the USB-C to USB-A adapter.
4) When you go to use the pairing tool, you'll see this, double click it.
Then, click Headset
pairing tool.pngClick RH200WLE
Run the firmware update tool.
update tool.pngThen check if you're able to pair.
this method needed headset pc mode? (hold function button 15 sec?)
Not worked. i tried on 2.4 mode and try to pair and tried 2.4 + function button (pc mode) but not worked.
When first time double click to "RH200WLE_FW_Update_tool" windows asked to me like "is that program worked normally"
Nate152
Thank you
Click Run anyway, not sure why it says that.
Have a read through this help article, you'll want to have the cable connected as well as the wireless dongle when using the pairing tool.
[Peripherals & Accessories][ROG Delta S Wireless] How to do if The 2.4G doesn't work, or the headset...
Ok, so to use
I've already trying this method for checking my problem status. and still im stuck on gray button step
