04-08-2020 10:17 AM
04-17-2020 12:33 PM
Joakingdom wrote:
Hi there!
I recently bought a pair of DELTA headphones from amazon so i could use them with my Scar II and everything worked just fine for several months. A few days ago i realized that the left RGB is not working anymore (Right RGB light is still working). I thought that it was a software related issue at first but i tried changing the profile in Armoury, updating the BIOS (firmware) but nothing seems to work.
I also have trouble trying to change the rgb presets, for example; I click on static color and there is still rainbow. Nothing changes. I'm not 100% sure but i recently updated something called: "AURA KIT / HAL / SDK Device firmware.
PS: Connecting the headphones to my cellphone doesn't seem to fix the rgb issue
Apart from that, everything works like a charm!. Any suggestions? i do think that the recent update messed up my headphones since they do not change RGB anymore, in the other hand, audio software and EQ still works. Is there a hard reset option anywhere?
Sadly, i bought them second hand so i'm sure if the support will help me if a repair is needed.
04-23-2020 07:45 AM
toonkl wrote:
I also have this problem. I bought the ROG Delta from the store a few month ago and today the left RGB light has stopped working and I could not set any light setting via Armoury Crate software.
04-24-2020 03:50 PM
04-26-2020 04:52 PM
08-01-2020 11:35 AM
08-09-2020 07:48 AM
09-25-2020 02:16 PM
saud141 wrote:
i have the same exact issue. Can't find any solution on internet and the asus support told me to contact the seller. Let me know if someone finds any solution.
09-27-2020 12:14 AM
11-02-2020 04:49 AM
