10-10-2025 02:28 PM
I just purchased an ROG Delta II headset and I cannot get the microphone and audio to work at the same time. Either the microphone works or the audio works, not both. I have updated them to the newest firmware as the microphone wasn't working before the update. I have restarted ArmouryCrate as well as my PC multiple times. I have tried switching the dongle from USB-C to USB-A. Nothing has fixed it.
10-10-2025 03:09 PM
Dello RogueKriger
Do you have the ROG Delta II headset and microphone selected in windows?
10-10-2025 04:27 PM
I do yes, I have double checked permissions, that enhancements were disabled, and that they were set as my default device.
10-10-2025 04:38 PM - edited 10-10-2025 04:44 PM
Do you have the microphone muted?
Press the volume wheel, the microphone will light up red when it's muted.
The microphone light will be off when it's not muted.
10-10-2025 06:02 PM
Microphone is not muted, tested multiple times. Red light is off and voice said "Microphone on"
10-10-2025 06:16 PM - edited 10-10-2025 06:17 PM
Ok,
Try running the windows troubleshooter for input and output devices.
Does it detect any issues?
