ROG Centurion 7.1 - 16bit/48khz max? What about 24bit or 32bit?
TEG2TEG
I got an ROG Centurion hoping for a really high quality DAC based on seeing ESS9601.
I installed latest drivers and app, but Windows 10 only offers me these choices from the sound driver:
16 bit, 44100 hz (CD quality)
16 bit, 48000 hz (DVD quality)
Is there any way to get anything better? I was hoping for at least 24 bit, 96000 hz (Studio quality)
or maybe even 32 bit, 192000hz
In Windows, my driver says:
ASUS ROG 7.1
Driver Provider: A-Volute
Driver Date: 11/24/2016
Driver Version: 8.12.15.485
( If I search for anything else it always says I have the best driver installed. )
I have Sonic Studio v1.1.20
Sound Card FW v1.0.6
Control Box FW v1.3
Thanks in advance for any helpful responses here.
15 REPLIES 15
TEG2TEG
I disabled the AMD HDMI audio in my Radeon card, and disabled my Realtek motherboard audio, so my only audio device is the Centurion USB base station.
94919
TEG2TEG
So...
Great answer would be:
"Here, use this driver and now you have 32/96!" (or at least 24/48)
Sobering answer would be:
"Sorry, we have a 16 bit DSP so there is no point in sending 24 or 32 bits to the Control Box even though it has a 32 bit headphone DAC."
Unfortunate answer would be:
"Yes, the Control Box operates at 32 bits, but unfortunately nobody works on that driver anymore, so you are stuck at 16 bits."
Bad answer would be:
Nobody wants to talk about it, so I am left in the dark wondering...
Note, I have read every Centurion review I could find, and nobody seemed to mention this as a limitation.
Does ANYONE see more than 16 bits from their Centurion device driver?
Note, my motherboard is a recent ASUS Prime Z490-P with USB 3.2 ports and such. I tried plugging the Centurion into all the various USB ports and always got 16 bits max from the driver.
TEG2TEG
TEG2TEG
Well, I guess I am out of luck. It appears that the Centurion control box uses a Realtek CM6210 chip which does 24/96 for Stereo, but only 16/48 for Multichannel.
Too bad Realtek didn't design the chip to take 24/48 on multi-channel.
Nate152
Thank you,
I don't have the ROG Centurion so I wasn't 100% sure, but I was wondering about the shared mode.
Based on that, it seems you'd use 24/96 stereo for music and 16/48 multichannel for games.
I got this headset for the 7.1 surround sound. I don't plan to put them in stereo mode, so will just leave them in 16/48 mode all the time, for games and 5.1 / 7.1 music. (Yes, there is a limited selection of surround sound music available.)
Most of the 5.1 & 7.1 music comes from Bluray and is 24bit sampled, so it is a shame that this DSP chip in the controller can't support that.
I have a better DAC and better stereo only headphones when I want to listen to stereo music.
I have a Soundblaster X3 that can do 32/96 Surround sound to a Razer Tiamat 7.1 headset that I was using before.
The audio sounds slightly clearer at the higher bit depth and sampling frequency, but I am sticking with the ROG Centurion because:
* It has richer/deeper bass than the Tiamats
* The Sonic Studio VU meters are very handy
* The Centurion beta firmware has that crossmix feature to convert 5.0 sound into 5.1 (driving the subwoofers) for some games and music that lacks LFE/sub encoding.
I am finding that the beta firmware feature to drive the subwoofer (when source audio lacks LFE encoding) only works in headset mode. I wish I could use that feature with the speakers out as well to drive some home theater speakers.
I realize that this is a discontinued product (although they are still available from Amazon) , so I don't really have any hope of any new (software/firmware) features being added...
