Realtek High Definition audio Not working HELP
dunedune
Hello .
It seems like after i reinstalled Intel HD Driver the realtek high definition audio Broke itself ... :mad: , Can somebody please drag download link for realtek high definition audio from Official Asus website ? my Boss expensive Head speaker not displaying Music very smoothly So please can anybody suggest a useful solutions?
Edit : I downloaded Driver from Asus website but its still same problem , the Audio is not same before it means not HD ,Just working on Default sound 😞 . I changed some settings but nothing happened
7 REPLIES 7
toronto699
what PC or laptop do u have? what OS
Win 8.1 64bit
ROG Asus G551JW
toronto699
Ok in search type "Realtek HD Audio Manager " u can change { set Audio Settings} from there , usually when a new realtek driver is installed u will have to reset the audio settings as new driver does not remember old settings . hope this helps . HD audio manager may be in the hidden icons lower right . if not , do the search for "realtek HD audio Manager"
This is the latest version Of realtek HD Audio . I still cannot realize which option is reseting for default Audio settings
take a look
http://postimg.org/image/rkcs8y9x5/
toronto699
D
http://support.asus.com/Download.aspx?SLanguage=en&m=G551JW&p=3&s=714
Check This , "Sound Control Panel" make Sure "RealTek High Definition Audio" Is Selected , Right click ON the speaker icon lower right then play back devices select "RealTek High Definition Audio"
u see the gear {*} in the top right of the HD Audio Manager click it to open select option connector settings and change the control panel options to HD Audio control panel
toronto699 wrote:
D
http://postimg.org/image/xnyve0qfp/
There"s so gear :confused: .
toronto699
on the first pic u posted there is a Gear when Speakers are selected not when micro phone is selected microphone
