Tuf Rtx 3080 but system read rtx 3060
Slaphead
Need help
13 REPLIES 13
Nate152
RTX 3060 12gb
Nate152
GPU Tweak III is showing you have an ASUS TUF RTX 3060.
GPU-Z shows you have an RTX 3060 as well.
What happened with the RTX 3080?
in the box is rtx 3080 same in serial number and sticker is rtx 3080 even in asus they said its rtx 3080 but they insist to provide invoice or receipt from the store i told them i bought in marketplace so i cant provide any invoice or receipt
Nate152
Sounds like someone is trying to pull a fast one, I might contact the person you bought it from on Marketplace and explain the situation.
Are you able to take a screenshot of the transaction?
yeah i did but you some people they scam other people i thought its legit because the serial number and sticker is the same both box and the gpu
Nate152
Unless there was a mistake at the ASUS factory with the serial numbers, which I highly doubt, it sounds like the seller swapped serial number stickers. Although, I don't know how easy or difficult this would be without damaging the stickers.
Did you purchase the TUF RTX 3080 used?
i dont think the seller switch the sticker the 2 sticker in gpu is the same in the box, and asus said its original sticker both in the box and the gpu
