In urgent need of help - regarding 4090 graphics card
Smith2503
I am desperately hoping someone can help me as I am now on my 4th Asus 4090 card and can’t get it to work. I have had 2 ASUS ROG TUF OC 4090,s and now it will be 2 ASUS ROG STRIX OC 4090,s.  Only one of them actually loaded up but died within 15 minutes of playing God of War.
This latest one won’t even install the drivers from Nvidia and doesn’t show up in the Device Manager. My old ASUS 3070 works fine.
This is my PC set up:
Luan-Li Galahad AIO 240mm HIgh performance RGB CPU water Cooler
Thermaltake tough power GF3 1200W power supply
ASUS ROG STRIX Z690-E Gaming Wifi Intel LGA 1700ATX Motherboard
Please can anyone help?
Silent_Scone
Super Moderator
Hello,
4 cards really indicate the issue is not with the GPU. Can you confirm if you're using the supplied power adapter?
Have you tried installing the GPU into the second full-length slot - PCIE16 (G3)?
Flash the motherboard to UEFI Revision 2305 if not done so already.
Hi
i have tried with and without the adapter
I have tried the second full length slot
I haven’t done the motherboard flash.
my ASU’s 3070 works fine.
Jiaszzz_ROG
Customer Service Agent
Hello, @Smith2503 .
It is recommended that you confirm whether the graphics card is installed correctly, the driver is updated to the latest version and compatible with the OS version, and cross-test with other cables.
Please update the BIOS to the latest version, if necessary.
