Help with gpu tweaker for energy optimisation
Blocky
I have a Dual RTX 2060 6G Evo and i need some help regarding energy optimization for the gpu.
Basically the power bills in my country are very high due to recent taxes, so I just need to find a way to optimize/limit my GPU from drawing too much. even on idle it draws around 15%. I run my PC 24/7 so I just need some advice on how to reduce the power consumption of my GPU.
Thanks!
Current GPU Tweak setup:
Silent_Scone
Super Moderator
The power target is already at minimum. Short of limiting your frame rate, that's as much as you can do.
