5090 tuf power cable - Seasonic 12VHPWR PCIe-adapterkabel, 90°
foxhoundutch
i ordered this power cable for my 5090 tuf , this cable is original cable bought for seasonic psu's
its already bend downwards so it would be safest way to prevent melting right ?
those nvidia things are so much cables and seeing so much melting cases i just rma my 4090 with cablemods adapter so i dont want it again 🙂
just one cable in my psu directly in the graphics card.
https://www.alternate.nl/Seasonic/12VHPWR-PCIe-adapterkabel-90-haaks/html/product/1917752
my specs
ASUS TUF Gaming GT501 -CASE
SEASONIC PRIME-GX-1300
ASUS TUF GAMING Z790-PLUS WIFI - SOCKET 1700
Intel Core i9-13900K 3000 1700 - WATERCOOLED - Corsair iCUE H150i Elite Capellix XT
Kingston FURY Renegade DDR5 - 32 GB: 2 x 16 GB - 288-PIN - 6400 MHz - CL32
2x 1TB Samsung 980 M.2 SSD Raid0
48 inch LG OLED evo C3 4K Smart TV
ASUS TUF Gaming GeForce RTX 5090 OC
2 ACCEPTED SOLUTIONS
Accepted Solutions
inge70
Level 15
I also use this cable with my Seasonic Prime 850, previously with a 4070Ti and now with a 5070Ti (although these GPUs don't draw as much power as a 5090).
The problem with the melting connectors wasn't with the connector itself, but rather with the contact between the individual pins in the connector.
You shouldn't have any problems with this connector, though. Just make sure the connector on the GPU side clicks into place and is properly seated.
Intel Core i7 13700K / AiO Fractal Design Lumen S36 v2 RGB / Asus Rog Strix Z790-F Gaming WIFI / Corsair Dominator Platinum DDR5-5600 64GB (4x 16GB) / Asus TUF RTX 5070 Ti OC / 4x Samsung 980 pro 1TB / Seasonic Prime GX 850 W Gold / Fractal Design Meshify 2 Lite RGB Black TG Light Tint / Monitor AOC Q27G2S/EU (WQHD)
right 😉
20 REPLIES 20
inge70
Level 15
that is the cable i had with my 4090 tuf but i think a new cable for a new graphics card is better so i know for sure its not damaged or wear and tear ..
thnx 😄 greets
Silent_Scone
Super Moderator
As above, this cable should be fine. The general consensus with 90 degree connectors is when you're adding an *additional* connector into the mix. Typically, adding additional junction points isn't advisable as you're just adding another point of potential failure in the chain.
i just want a fresh cable for this new graphics card. i dont know if this cable or how long it will last after my 4090 melting ******show, and the bending to much issue is miminal with this cable because its already going down so the bending is already done for me.  right ? 😄
right 😉
IMG-20250513-WA0011.jpgIMG-20250513-WA0012.jpgIMG-20250513-WA0013.jpgIMG-20250513-WA0014.jpgIMG-20250513-WA0015.jpgIMG-20250513-WA0016.jpg
wtf ! i thought of using original cable but i dont get the last bit whole the way in ! and it dont make a click sound! what is that for crapp cables :S
According to your pictures, the connector is fully inserted. The retaining clip at the top is also completely behind the retaining lug of the socket.
This click only comes from the small clip at the top, which slides behind the retaining lug.
Sometimes you can barely hear it because it's very quiet, but you can also feel it a little.
At least, that's been the case with my Seasonic cable so far.
I've had two of them: 1x 12VHPWR and, since my 5070Ti, a 12V2x6 (the newer version of the 12VHPWR, where the four small sense pins are positioned a little further back to ensure the connector is fully inserted).
But both cable versions should work flawlessly with the Blackwell.
Otherwise, if you're unsure, unplug the connector and plug it back in again, listening for the "click" and whether you can feel it click into place.
As said, it looks to be fully inserted.
