PC help
edeisk9
hey so I have the G15CX-B10 desktop and was wondering if upgrading any of the parts is worth it and what kind of cpu and gpu would be a good upgrade for it to handle. Mostly play fps games like cod and valorant.
Aureliannn_ROG
Customer Service Agent
Hi @edeisk9 ,
Thank you for your interest in upgrading your ROG G15CX-B10 desktop.
To provide you with the most accurate upgrade recommendations, we would like to better understand the issues you are currently experiencing.
Are you experiencing any of the following when running games like Call of Duty and Valorant:
  • Stuttering or low frame rates?
  • Excessive system temperatures?
If you are experiencing these issues, we recommend that you refer to "Chapter 5" in the following product manual.
E22433_G15CX_Win10_UM_v2_WEB.pdf
