NUC 970 Armoury Crate doesn't show fan speed
Buzzy42
Not sure if this is the right place or not.
I recently purchased a NUC 970 (awesome little unit!). Whenever I get any new PC, I wipe out the Windows installation and start over. Everything has been great, except now on Armoury Crate, I do not see CPU fan speed or fan acoustics. It also only shows Power presets for "Windows/Silent/Performance/Turbo". I don't remember if there should be a "Manual" setting there like on laptops for controlling the fan curves/etc.
(I used the large 3gb driver package from the support page to reinstall all of the drivers after I reinstalled Windows)
If I look in HWInfo the fans do appear to be working, so that's good. But I'm trying to figure out how to get it working on
G-Helper does not seem to have much functionality on this device, even though it's mostly all laptop chips...
I know on Asus laptops it's critical to save the "Esupport" folder to get the full/correct set of drivers if you need to reinstall AC but I didn't see anything like that on the  NUC. I did image the drive before I wiped it, in case I need to dig anything up. Anyone have any ideas what's missing?
0 REPLIES 0
