GA35DX Having Problems Playing BO7
Huikv
Same issues as previous users posted (g15DK and G10DK)
TPM Issue
AMD users especially have an TPM 2.00 issue , there is a known problem caused by an outdated fTPM firmware version, SPECIFICALLY any version ending in .0.x. (third digit is zero)
To fix this, users must update their motherboard's BIOS to a version that includes the necessary TPM module update (ending in .2.x).
EXample, if you have 3.94.0.5 where the third number is 0 (zero) thats a problem. If you have 3.X.2.x where the third number is a two or higher then you are fine.
My current version is 3.51.0.5 and as you can see the third number is a zero and such I can't run Black OPs7 or new games coming out.
There have been updates to ASUS motherboards to fix this issue, so I know they are aware of it.
Below is error message I am receiving. This PC came with Windows 11 pro. Boot secure is enabled as well as TPM
Error Message I receiveError Message I receive
0 REPLIES 0
