08-20-2024 06:31 PM
My gpu power usage (watts) starts to drop then my gpu utilization ruining my fps in games i should easily be able to run. I have a pretty brand new high end pc.. my specs are
specs ; 4070 TI SUPER , AMD RYZEN 9 7950X3D , ASUS TUF GAMING B650-PLUS WIFI with 32 gb of DDR5 6000mhz and a CORSAIR RM1000x Modular ATX Power Supply - 80 PLUS everything isnt even a year old yet
All of my drivers are up to date like : GPU , CPU CHIPSETS , MOBO BIOS / CHIPSETS.. only thing i could thing after weeks of trying is my 16 pin pcie to my gpu is messed up as it does look off in a post where the protective cover isnt fully secure and i can see its wires.. came like that with the gpu..
one thing to note that i found out.. i used the pcie pigtail so one pcie to power my gpu.. i just recently used 2 diffrent pcies in the 12VHPWR.. its been running for a long time on one pcie could this have caused damage..?
08-22-2024 11:56 PM
Hi @arkyblarky1 ,
thank you very much for providing detailed information.
Regarding the issue you are experiencing with the power usage, utilization, and frame rate reduction on your 4070 TI SUPER graphics card, if you notice any obvious damage to the connectors or their surroundings, we recommend contacting your local customer service for further assistance or you can directly send the graphics card to the nearest official repair center.
Thank you very much for your cooperation.
