ROG Delta - Sound Optimization doesn't work
JuleJules
After I updated AC, Sound Optimization doesn't work. I tried to change to FPS, Music or other but it is not work. And Reverb, Equalizer, Bass Boost, other are not work too.
I uninstalled AC with uninstall tool and reinstall but still doesn't work.
14 REPLIES 14
Aureliannn_ROG
Customer Service Agent
Hi @JuleJules @AMORAKI ,
based on your issue, have you attempted to reinstall the Bongiovi driver?
Please try reinstalling it and ensure that the Audio SDK is also updated.
After completing all updates, restart your computer to check if the audio can be adjusted.
Additionally, the Bongiovi reverb effect is relatively subtle and requires a higher setting to be noticeably effective.
Please note that response times may be delayed due to upcoming regional holidays. For urgent inquiries, please contact your local service center. Thank you for your patience.
Hi. I deleted all files what is related with Bongiovi after deleting Armoury Crate. Now after install armoury crate, bongiovi is not instal more, where i can download this driver ?
AMORAKI
HerbalMan420
I have a similar problem to you except with the ROG Delta S. Did they ever fix it?
