ROG Delta II Wireless Headset Loose / Big on Head
AstroSamz
Hi Everyone, I have been using the ROG Delta II Wireless Gaming headset for a couple days now and I have really been enjoying it. My only concern is at the lowest height, it's very loose. I was wondering if anyone has any suggestions on how to make it tighter or increase the clamp force?
I look forward to your advise and opinions. Thank you.
Aureliannn_ROG
Customer Service Agent
Hi @AstroSamz ,
Thank you for contacting ASUS support.
We understand that you are experiencing an issue with the headband of your ROG Delta II wireless gaming headset feeling too loose, even when adjusted to its tightest setting.
Due to the design of our headband, it cannot be replaced. To address this issue, we suggest considering the use of third-party accessories such as headband pads or clamping devices.
Providing detailed device specifications (MB/CPU/GPU/PSU, etc.) and the respective driver versions, OS version, and BIOS version will help us analyze the issue more effectively.
Do you have any suggestions for headband pads or clamping devices? Thank you.  Any chance for thicker earpad cushions?
