ROG Cetra True Wireless Speednova cutting out beginning of sounds after idle period
PWN3D_
Level 12
Hello,
I just picked these ROG Cetra True Wireless Speednova up to test, and unfortunately, I've noticed something: the exact same behavior as the ROG Delta II headset firmware issue I reported last year, which has since been fixed. : Solved: Noticed an issue with the new ROG Delta II - Republic of Gamers Forum - 1045438
The issue is the exact same as before:
When there is a period of silence (5/10 sec) it sound like the Cetras is going idle and when the sound resume, it take half a second to a second to hear it again (there is a fade before the sound resume). Meaning if I mute a video for a few moments and unmute it, you can miss some dialogue or context due to the fading. Same thing happen if I pause and unpause a video/song.
A reliable way to replicate it is by using Google Translate in a browser: translate a word and click the speaker icon to listen. If you wait 10 seconds before clicking, the beginning of the word is inaudible.
It seems that this "bad " behaviour and coding lines on the delta II firmware has been ported or is remaining on the Cetra True Wireless Speednova, maybe more of your audio devices?
This issue happens only with the 2.4GHz dongle, while it works perfectly over Bluetooth.
Devices version 02.08.08.00
Dongle version 02.06.03.00
I unfortunately can't be certain if the default firmware exhibits this behavior.
@Silent_Scone Sorry for the @ but can you push this issue to the concerned team for review/fix?
Thanks!
PWN3D_
Level 12
@Silent_Scone Just realised this thread should be in Hardware & Software Support > Game Audio. Is it possible to move this to the right place? If not I'll simply delete it and recreate it there.
Thanks!
