Latest firmware for ROG Delta II cause them to be detected as "Speakers"
PWN3D_
Level 12
Hello,
Little regression with no consequences as far as I tested, but since firmware 00.04.08.00 for the ROG Delta II headset, they are now detected as "Speakers" instead of "Headphone" on Windows 10 and 11 (tested two different system)
I have not noticed any other issue due to that but it's now really confusing to navigate through all my audio devices 😕
@Aureliannn_ROG @Jiaszzz_ROG Can you guys confirm the issue with the concerned team?
Thanks!
10 REPLIES 10
JiDiz
This happened to me as well and there are consequences. In-game the sound is not as good as it was. Something changed.
+1
Aureliannn_ROG
Customer Service Agent
Hi @PWN3D_  and @JiDiz ,
Thank you for reporting the issue with your ROG Delta II headset, where after updating to the latest firmware 00.04.08.00, it appears as “Speakers” instead of “Headphones” on Windows 10 / 11.
To assist further, please help confirm the following:
  1. Verify the device name and audio output settings.
  2. Check if Armoury Crate can properly detect the headset.
Additionally, please provide:
  • A screenshot showing “Speakers” in your system
  • The product serial number (S/N) via private message
Once received, we’ll forward this information to our technical team for further review.
Thank you for your cooperation.
Hi @Aureliannn_ROG and thanks again for your assistance
In Armoury Crate the Delta II is properly detected and settings do affect the sound of the headset as usual:
Here are few screenshot of the Delta II showing as "Speakers" ("Enceinte" in French OS system)  in multiple locations on Windows 11, Sound settings, System Tray and Sound Parameter from Control Panel:
Capture d'écran 2025-11-10 193557.pngCapture d'écran 2025-11-10 193636.pngCapture d'écran 2025-11-10 193725.png
I'll proceed and send you the Serial Number of the Headset via private message
Thanks!
This actually broke my Delta 2  now. Even if I select the Delta 2, the audio still goes through the laptop speaker, with even worse sound than when I choose the laptop speaker instead. T_T
MrAgapiGC
Level 16
i have to check my old notes from v2.6 until today (many many years). but i think there was a time was headphones on windows. but most where speakers now. i own 2 and both comes as speakers here are my thetas. i know we love the part of the headphones. but mostly is windows side to id what is a speakers and what is a headphones and more when they are usb devices same as out audio. If on ac is ok then all is ok. maybe one day windows sort this out eventually. be sure is ok. I think the ones that are BT only appears as headphones.
Report can be send so they can check this with MS so they fill the id together. but will be nice. good spot there.
Learn, Play Enjoy! We help and collaborate, NOT complain!
Teyroks
I have that problem too. After updating the firmware version to 00.04.08.00, the headphones are identified as speakers, and the sound quality has become terrible. Extraneous noises
Have you found a fix for this? Looking at some stuff I saw the Realtek “fix” for it but that did not work at all
Aureliannn_ROG
Hi all,
thank you for the information you've provided.
We've passed your details on to our relevant backend team for analysis.
Please be patient and wait for any updates or messages from us.
