Bongiovi Acoustics/audio enhancements causes problems
LEGENDKMS
I need to turn off this feature permanently. This audio enhancement has been making my audio pop. Every time I try to disable it, it re-enables itself. If I want it disabled, it should be disabled. My audio works fine when it is disabled.
98 REPLIES 98
This is not addressed to you, but to everyone in general, it gives an example of how the microphone does not work with Latest Z790
Gotcha.
Xtracker
Asus or moderators that have some power... to link to engineering team.. when we see update Realtek Drivers on ASUS ROG site Any Z790 I or II gen boards ? currently is 2023-10 .. only 1 driver avaible boosting mic don't work.. only fix is user your armoury create because of  Bongiovi Acoustics driver...
Please..
jojoe48
Same noise problem with my Asus Rog Clavis USB Dac .
achugh
Level 14
I just built a brand new machine using ROG Maximus Z790 Dark hero with i9-14900K, 192 GB RAM and TUF Gaming RTX 4090 OC nVidia card.
I installed every driver staying disconnected from the internet. The moment I connected to internet, Armory Crate installed itself and the first thing it installed are these Bongiovi Acoustics Audio Enhancements drivers version 1.0.0.48
How do I test if I have an issue and where exactly do you see these Audio Enhancements like Sound or Mixer Settings or Realtek Audio Console etc.?
Disclaimer: I am not an ASUS support person so my information may be incomplete. Always follow official documentation and material provided by ASUS representatives.
INTEL i9-14900K / CORSAIR VENGEANCE RGB 192GB (4x48GB) 5200 CAS38 / ROG Z790 DARK HERO / ROG TUF GAMING RTX 4090 OC / ProArt PA-602 Case / SEASONIC PRIME TX-1300 ATX 3.0 / CORSAIR MP700 PRO 2TB PCIe Gen5 / CRUCIAL T500 2TB PCIe Gen4 / EIZO CG2700X
GettnBetter
I have had nothing but problems with audio on my Z790 Apex Encore also.  I use the analog outputs only.  This bongiovi is strange, can't get rid of it here either.  No idea where it came from or why it keeps reappearing.  The audio drivers are missing some basic functions as well, like the equalizer.  Seems every new generation of the SupremeFX audio gets worse.  I still don't get what the giant DTS thing is, seems to do nothing and offers nothing.  Ohh and despite removing or disabling bongiovi, there is a huge pop from the audio with each boot.  I've tried moving around USB devices and booting without any USB connected, still pops.  Think there are some glaring issues here with the audio drivers.
I came here looking for a solution and the person who recommended using the driver store app from github WORKED.  I know this is an old thread, but I wanted to say the ISSUE IS STILL THERE. I have a logitech pro x wireless headset and I completely lost surround sound.  I only happened to notice the bongi (whatever it is) when I went to do a system restore to correct the problem.  I looked at "affected programs" before the THIRD restore and saw it there as an "audio" something or other.  So I started to research which led me here.  The choosen solution for this thread is not the correct one.  The one about using the driver store is.
I have a Z790 Apex Encore with the above mentioned headset.  All drivers are up-to-date on my motherboard.  Deleting those two drivers in driver store and rebooting brought my surround sound back to my headset!
achugh
Level 14
@outlaw78 I am having issues with my microphone volume and the pops as soon as the Microphone is put into recording mode. See https://rog-forum.asus.com/t5/gaming-motherboards/re-rog-maximus-z790-dark-hero-low-microphone-volum... with my issues and steps I have taken so far which has not fixed the problem for me including uninstalling Bongiovi Drivers.
If you have uninstalled Bongiovi drivers and are still having issues, please check if you see C:\Windows\System32\Bongiovi\MB\BongioviAPO.dll file on your machine. If you do, can you delete this file or you get an error that this file is in use by audiodg.exe process. Or something like the file is in use error.
If you get any of these errors then it means, the uninstallation was not successful, as was the case for me and I had to go to extreme lengths trying to cleanup my registry manually.
Canis_Majoris
This issue needs to be elevated to develop a patch. Here is why:
I am pretty sure that this is supposed to be paired with the Bongiovi DPS software (or something like that to secondarily control output)
which is at End of Life (E.O.L). See: https://bongiovidps.com/support/
Furthermore if current integration is an issue the SDK can be found at:
https://sdk.bongiovidps.com/realtek-platforms/ as that is the chipset you are using.
I keep getting a random POP as well as really bad distortion on any Bluetooth headset I try. After searching everywhere for  a solution and finding none i found this high impact startup service named RoutingService supplied by Bongiovi Acoustics this company boasts that is one of ASUS's suppliers as well https://bongiovidps.com/ . This also appears to not have been updated since 2018.
