Rog Raikiri pro calibration problem or other
godam22
I bought a raikiri pro and I have a problem!
When I'm playing, black ops 6, my soldier turns on himself quite frequently!
Update done, appairing ok, driver downloading and installed.
No positive result, the problem is always there.
Can you help me?
Aureliannn_ROG
Customer Service Agent
Hi @godam22 ,
Regarding the issue of your character spinning frequently while playing Call of Duty: Black Ops Cold War, we would like to gather more information to assist you better.
Please help us confirm the following:
  1. When did the problem start: Was this issue present from the beginning when you purchased the controller, or did it appear later?
  2. Connection modes: Does the character spinning issue occur in all connection modes, including USB-C®, 2.4 GHz RF, and Bluetooth®?
  3. Other games: Have you tried using the controller in other games? This will help determine if the issue is with the controller itself or the game settings.
  4. Software settings: Have you downloaded Armoury Crate and adjusted the stick response curve or made other calibrations?
  5. Controller condition: Please check if there is any damage or deformation to the controller's exterior, as this may affect the internal components.
  6. Game updates: Please ensure that Call of Duty: Black Ops Cold War is updated to the latest version, as some updates may have fixed related bugs.
If you have confirmed that none of the above issues exist, we recommend that you send the controller to a nearby authorized service center for further inspection by our professional engineers.
Thank you for your patience and cooperation.
