No LED lights on my Hyperion case
lzb2811
I recently bought a Hyperion case. It comes with a RGB hub at the back of the case. My motherboard is Asrock x670e Taichi Cararra.
I've followed the instruction and connect the PWM to pin 31, ARGB to pin 29 and also the power cable.
The PC boot up fine and I can control the fan but I can't get the LED lights to turn on. The AIO fan will run but the LED won't lit. I went to armor crate it doesn't see the HUB. I'm running out of ideas. Can someone please shed some light? Much appreciated.
lzb2811
Ok one of the LED pin i connect to has some issue, after removing it the LED now works.
