on 10-07-2025 07:47 PM
[Wireless Router] Why am I unable to use my mobile hotspot connection properly? (RT-AX50 Go)
If you find that your RT-AX50 Go is not functioning correctly when using USB tethering, please refer to the following possible reasons and solutions.
Possible Reasons:
Solutions:
1. Use a Compatible Charger: Make sure you are using a charger or power bank that supports the standard Power Delivery (PD) protocol.
2. Change the USB Cable: Try using a different USB cable and attempt the setup again.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
