FAQBot
Community Admin
Community Admin
[Wireless Router] Tips to keep network connection stable
Nowadays dropping Internet connection will be a big deal, there are many reasons to cause Internet drops such as outdated router, compatibility issues of connected devices, ISP provides modem issues...etc.
To do a quick fix for the Internet dropouts of all connected devices, you can follow the steps below:
  1. Power cycle your modem.
  2. Power cycle your router.
  3. Check your Internet cable is plugged well and healthy. (Please refer to [Wireless Router] How to check the wired connection speed and network cable specifications for ASUS ...)
  4. Set up schedule reboot for your router.
If the above steps didn't resolve your case, you can refer to this FAQ: [Troubleshooting] Failed Internet access through router
There are also some factor slight cause Wi-Fi dropout on certain devices. Normally it occurs on a few devices which cannot connect to Wi-Fi network properly in your home, while other devices work just fine. To fix this, you can follow the steps below:
  1. Disable smart connect on router.
           Please refer to [Wireless Router] How to configure the Smart Connect in ASUS Router?
  1. Set up fix channels of your Wi-Fi network, the best compatibility channels are: for 2.4GHz network, channel 1, 6, 11 are suggested, for 5GHz, channel 36~48 are recommended.
    Please refer to[Wireless] How to fix wireless Control Channel?
  1. Adjust Wi-Fi bandwidth, higher Wi-Fi bandwidth can improve maximum connection speed but also generate more interferences, you can set up lower bandwidth to avoid.
    Please refer to[Wireless] How to improve wireless speed by setting Channel Bandwidth in Wireless Router?
  1. Try to forget Wi-Fi connection and reconnect your device to the Wi-Fi network.
    Please refer to [Wireless] How to forget WiFi connection password on Windows/MacOS/Android/iOS?
  1. Stay close to the Wi-Fi router, if you put device too far away from router, signal strength might not be good. If you have a large house or space, you might need to install mesh Wi-Fi to get the best wireless coverage.
  2. If above steps do not resolve your issue, you can check this:
  [Wireless] How to improve compatibility of IoT device with ASUS WiFi 6(AX) Router?
  [Troubleshooting] Wi-Fi signal is often disconnected
  [Troubleshooting] Computer cannot find the wireless router
Improve overall Internet connection quality
To improve overall Internet connection quality is essential today, we play games, host online meetings and watch streaming videos all the time, here are some tips to optimize your Internet:
  1. Find a best DNS server for your router, a best DNS will improve general website surfing experiences, to look for a best one, you can refer to: [Wireless Router] How to find the best DNS server?
  2. Disable VPN connection. You might already dial VPN connection on the router or PCs, with a VPN connected, all traffics will go through VPN server which will slow down all the browsing experiences, it’s important to disable VPN while gaming or streaming.
  3. Enable or disable QoS (Quality of server) by cases, QoS will deal great experiences improvement while Internet speed is limited. For example your Internet speed is lower than 100Mbps. However with high Internet bandwidth, QoS might cause the limitation of maximum speed.
All works fine but still expecting a greater performance? Find a better router!
Sometimes it’s not worth to troubleshoot an outdated router which uses outdated wireless technologies and has a very limited transmission power. Instead, buy a newer router instantly enjoy improved signal strength with faster download and upload speeds could be an even better offer.
You can refer to key factors below:
  1. What bandwidth plans you get from ISP? With bandwidth over 300Mbps, AC1750 or AX1800 above are recommended.
  2. How large is your home? For single room or 3 rooms apartment, a single powerful router might be good, but for a large house, multi-floors, Wi-Fi mesh should be a better choice.
Version history
Last update:
‎04-11-2025 12:53 AM
Updated by:
