FAQBot
Community Admin
Community Admin
[Wireless Router] How to fix disconnection in Public WiFi Mode(WISP)? (RT-AX50 Go)
If you experience disconnection issues while using RT-AX50 Go in Public WiFi Mode(WISP), please refer to the following troubleshooting steps.
Step-by-Step Instructions:
1. Check LED Indicator Status
  • If the LED is red, it means disconnected from the Parent WiFi network. Please click [Change Network] to connect to another available WiFi network.
  • If the LED is blinking blue, the device is connecting to the Parent WiFi network. This process may take 1–2 minutes. If the status does not change, please click [Change Network] to select a different WiFi network.
2. Switch Operating Mode (if needed)
   If you wish to change the operation mode, click to access the configuration page and reconfigure RT-AX50 Go to another mode.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
Version history
Last update:
‎10-07-2025 07:47 PM
Updated by:
