on 10-07-2025 07:47 PM
[Wireless Router] How to fix disconnection in Access Point(AP) Mode? (RT-AX50 Go)
If you experience disconnection issues while using RT-AX50 Go in Access Point(AP) Mode, please refer to the following troubleshooting steps.
Step-by-Step Instructions:
1. Check Network Cable Connection
Ensure the network cable is properly and securely plugged into RT-AX50 Go and the upstream router.
2. Check LED Indicator Status
If the LED is solid white, please check the internet connection of the upstream router or your ISP.
3. Switch Operating Mode (if needed)
If you wish to change the operation mode, click
to access the configuration page and reconfigure RT-AX50 Go to another mode.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
