on 10-07-2025 07:47 PM
[Wireless Router] How do I factory reset my RT-AX50 Go?
When should I perform a factory reset?
If you want to clear all the settings in your RT-AX50 Go into default settings, you could try the following method to reset the router.
Additionally, if your RT-AX50 Go is not working properly or you are unable to change its settings, a factory reset may be necessary.
Note: After the restoration, the router settings are all cleared. If your Internet connection requires an account and password or special settings, please save the information in advance or ask your Internet Service Provider (ISP) first.
Factory Reset Steps:
1. Locate the reset button on your RT-AX50 Go.
2. Press and hold the reset button for about 7 seconds.
3. The LED indicator will flash yellow.
4. Release the reset button.
5. The RT-AX50 Go will perform a factory reset and automatically reboot.
6. Then could try again to enter the WEB GUI of the router.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
