on
09-25-2023
10:28 PM
- edited on
04-09-2025
07:01 PM
by
ROGBot
[Guest Network Pro] What is Guest Network Pro?
ASUS Guest Network Pro is an enhanced version of the Guest Network, allowing you to create multiple independent networks and VLAN combinations. It enables different access permissions, bandwidth management, and content filtering for each network, and even includes a dedicated network for IoT devices. This provides you with an efficient, secure, and easy-to-manage networking solution.
Notes:
1. Adding a Guest Network Pro also creates a new VLAN network.
2. Guest Network Pro is supported on WiFi 7 ROG series models and select WiFi 6 models.
3. This feature requires upgrading your ASUS router to firmware version 3.0.0.6.102_34312 or above.
Key Features of ASUS Guest Network Pro:
[Guest Network Pro] How to set up Guest Portal?
[Guest Network Pro] How to set up Kid's Network?
[Guest Network Pro] How to set up IoT Network?
[Guest Network Pro] How to set up VPN Network?
MLO feature is enabled by default. You can go to [Wireless] > [MLO] to make sure this feature is enabled before creating a MLO WiFi network.
Below are the instructions on enabling MLO functionality for Main WiFi Network and MLO WiFi Network of Guest Network Pro
(1) Go to [Network] > [Main network profile] > [Advanced Settings], click[Multi-Link Operation(MLO)] to enable this feature, and click [Apply] to finish.
(2) Go to [Network], under Guest Network Pro, click [Add Network] > [Multi-Link Operation(MLO)] to create MLO WiFi network.
For more detailed instructions, please refer to this FAQ [Wi-Fi 7 Wireless Router] What is MLO (multi-link Operation) and how it works?
ASUS Guest Network Pro not only enhances network security but also increases flexibility and convenience. Choose ASUS for an unparalleled network management experience.
