on 10-07-2024 09:14 PM
[Guest Network Pro] How to set up VPN Network?
Introduction
What is VPN Network?
The VPN Network on ASUS routers provide a secure internet connection by routing traffic through a VPN, ensuring encrypted and safe data. Setting it up involves creating a dedicated SSID and configuring VPN settings using protocols like SurfsharkⓇ, NordVPNⓇ, CyberGhostⓇ, or WireGuardⓇ etc. ASUS routers support popular VPN services, making setup easy. Devices connected to the VPN Network automatically route their traffic through the VPN, simplifying security. It also supports scheduling and bandwidth management to optimize network performance and security, especially for devices that don't easily support VPNs, such as smart TVs and gaming consoles.
Why We Need VPN Network?
Using a VPN network enhances online privacy by masking your IP address and encrypting your data. VPN network provides a convenient and secure way to manage your online activities, ensuring privacy and security for all connected devices.
The VPN network optimizes the VPN Fusion setup process, eliminating the need to configure each client's VPN settings. Instead, you can manage specific VPN settings directly through the SSID.
Notes:
1. This feature requires upgrading your ASUS router to firmware version 3.0.0.6.102_34312 or above.
2. Due to region restrictions, some of the regions may not support SurfsharkⓇ, NordVPNⓇ and CyberGhostⓇ.
3. Starting from firmware version 3.0.0.6.102_35404, the name will change from [Guest Network Pro] to [Network].
You can set up your ASUS router via Web GUI or ASUS Router app.
Step 1: Connect your device (laptop or phone) to the router via wired or WiFi connection and enter your router LAN IP or router URL http://www.asusrouter.com to the WEB GUI.
Step 2: Enter your login username and password on the login page and then click [Sign In].
Step 3: Go to [Guest Network Pro] > [VPN Network].
Step 4: Enter the required settings and click [Apply] to finish.
Step 1: Login to App and click [ Settings ] > [ Guest Network Pro ] > [ + ] icon.
Step 2: Click [ VPN Network ], enter the required settings and click [ Apply ] to finish.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
