on
09-25-2023
10:28 PM
- edited on
03-06-2024
11:27 PM
by
ROGBot
[AiMesh] How to set up ASUS AiMesh or ZenWiFi Mesh Ethernet backhaul under different conditions ? (Advanced setup with network switch)
To provide you more detailed instruction, you can also click ASUS Youtube video link below to know more about how to set up Ethernet Backhaul Mode/Backhaul Connection Priority in AiMesh System
https://www.youtube.com/watch?v=hPeyu_iWUvc
Prepare
When setting up AiMesh/ZenWiFi Router with network switch, please double check the following items:
By using AiMesh/ZenWiFi system, please make sure the node ports are NOT connected to trunk ports.
Scenario 1: For the Basic method to set up Ethernet backhaul, please refer to this:
[AiMesh] Can I set up wired connection between AiMesh routers (Ethernet backhaul)?
Scenario 2: Use AiMesh or ZenWiFi with network switch , and use the Main AiMesh router as Router mode.
To ensure the best Mesh performance, please make sure the switch supports 10/100/1000Tbase, and all network cables (RJ45) are CAT5e or greater spec.
In this case, the Main AiMesh router which directly connects to your modem needs to be set in router mode, and the Main AiMesh router provides IP address to all other mesh nodes.
To ensure network switch compatibility, please set the Connection Priority to “Ethernet” in mesh node settings.
Scenario 3: Use AiMesh or ZenWiFi with network switch, and use the Main AiMesh router as AP mode (Bridge mode).
To ensure the best Mesh performance, please make sure the switch supports 10/100/1000Tbase, and all network cables (RJ45) are CAT5e or greater.
In this case, the Main AiMesh router which directly connects to switch need to be set in AP mode (Bridge mode), and then it will get IP address from your modem.
[Note 1] Please ensure whether your modem provides DHCP service if you want to use this setup. (Please double check with your Internet service provider).
[Note 2] Some Internet service provider’s modem restricts the specific device or only allows one device to get IP address. In this case, you need to consult with your internet service provider for support.
To ensure network switch compatibility, please set connection priority to “Ethernet” in mesh node settings.
Scenario 4: Directly use AiMesh or ZenWiFi with modem and use the Main AiMesh router as AP mode (Bridge mode).
To ensure the best Mesh performance, It is recommended that all network cables (RJ45) be CAT5e or larger.
In this case, the Main AiMesh router and all other AiMesh nodes which directly connect to your modem need to be set in AP mode (Bridge mode), and it will get IP address from your modem.
To ensure device compatibility, please set connection priority to “Ethernet” in mesh node settings.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer to this link.
