FAQBot
Community Admin
Community Admin
[AI Router] WiFi Insight
1. Overview
    WiFi Insight visualizes invisible wireless environment data—band/channel usage, interference heatmap, and reasons for channel or bandwidth changes—using intuitive charts. It helps you quickly decide whether to change channels, adjust bandwidth, move devices, or keep your current setup.
2. What Problems Does It Target?
  • Reveals if your current channel is crowded (avoiding blind manual channel locking).
  • Explains why your router automatically changes channel/bandwidth (event tags).
  • Distinguishes interference sources: other Wi-Fi, non-Wi-Fi devices, regulations (DFS/RADAR).
  • Provides a basis for narrowing bandwidth, switching between 2.4/5/6 GHz bands, or adding mesh nodes.
3. Interface Guide
    (1) Band switch: toggle between 2.4 / 5 / 6 GHz.
    (2) Event list: shows each channel/bandwidth change (with time and reason tags).
    (3) In Channel Interference line chart: shows the percentage of interference on the current channel over time.
    (4) Spectrum heatmap: displays interference intensity across all channels in the selected band; deeper colors mean higher interference. The blue box marks the router's active channel (or bandwidth range).
    (5) Filter buttons: Channel in use / DFS / Others WiFi interference / NonWiFi interference, to control what is shown.
    (6) Advanced settings: top-right menu lets you enable/disable detection and auto-refresh, and set the chart time range (10M / 1H / 12H / 1D).
4. Troubleshooting Common Connection Issues
ScenarioHow to Judge from the Interface Recommended Action
Slow Wi-Fi?Check In Channel Interference trend + Spectrum heatmapSwitch to a cleaner channel or band
Why did my channel just change?Event list tags (Optimized / Manual / RADAR, etc.)Decide whether to keep auto or switch to manual settings
Should I use 160MHz?Check interference in the Spectrum heatmapIf crowded, use 80/40MHz; if clean, keep wide bandwidth
2.4GHz connection issuesNonWiFi interference and Others WiFi interference indicatorsRemove interfering devices (microwave, other 2.4GHz devices) or move the router
High latency on 2.4GHz devicesHigh NonWiFi/Others WiFi interferenceSwitch to a cleaner channel or band
High NonWiFi indicatorExternal non-Wi-Fi device interferenceRemove interfering devices or change router location
5. Chart Colors and Tag Meanings
ElementMeaning
Darker heatmap colorsHigher interference, crowded channels or more noise
Red/dark blocksHigh interference, channel not recommended
Blue boxCurrent active channel or bandwidth range
Tag: Initial auto selectionChannel selected automatically at boot or first setup
Tag: Optimized automaticallySystem auto-adjusts based on interference or regulations
Tag: Manually configuredUser manually changed settings
Tag: Adaptive Bandwidth Expand/ReduceSystem dynamically adjusts bandwidth for balance
Tag: Regulatory (RADAR)Radar detected, must leave or change channel
Tag: Regulatory (Channel conflict)Channel conflict detected, must change channel
Tag: InterferenceHigh environmental interference, should change channel
Tag: Interference (TXFAIL)High interference causing transmission failures, should change channel
6. Glossary
Term
Description
Notes
BandWireless operating frequency range, commonly 2.4 GHz, 5 GHz, 6 GHz. Each has different channel counts, penetration, and interference sources. 2.4 GHz penetrates walls well but is easily interfered; 5/6 GHz have more channels and speed but less penetration.Switch bands based on device support and crowding to avoid interference
ChannelEach band contains multiple channels; the router communicates on a selected channel.Watch for crowded channels; overlapping or heavily used channels cause interference. Choose less-used or cleaner channels
SpectrumInterference distribution across all channels in a bandUse to find cleaner channels
In Channel InterferencePercentage of interference on the current channel over timeIf high, consider changing channel or narrowing bandwidth
Band (2.4/5/6 GHz)Different frequency ranges; higher bands have more channels and less interferenceIf possible, connect devices to higher bands to avoid crowding
Channel Width (20/40/80/160 MHz)Spectrum width used; wider means higher speed but more prone to interferenceIf crowded, narrow width for stability; if clean, keep wide for speed
DFSDynamic Frequency Selection: regulatory requirement—when radar is detected, router must leave the affected channel and switch. Prevents interference with weather/aviation radar.If radar is frequent, disable "auto-select DFS channels" to avoid frequent disconnects
NonWiFi interferenceNoise from non-Wi-Fi devicesRemove interference sources or move router
Others WiFi interferenceInterference from other Wi-Fi APs nearbyIf severe, switch to less-used channel/band
7. Best Practices
  • Prefer automatic channel selection to avoid locking onto crowded channels.
  • If the heatmap is mostly red for a long time, narrow bandwidth or switch bands.
  • If 2.4 GHz is noisy, don't force 40MHz; use 5 or 6 GHz if you need speed.
8. Notes
  • Features and interface may vary by region due to regulations.
  • When the router switches channels, all devices on that channel will briefly disconnect and reconnect automatically. If interference is still acceptable, the system will try to keep the current channel to minimize interruptions.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
Version history
Last update:
‎10-25-2025 10:02 AM
Updated by:
