on
09-20-2023
06:00 PM
- edited on
03-06-2024
11:25 PM
by
ROGBot
[Motherboard] Two-Way AI Noise Cancelation - Introduction
About Two-Way AI Noise Cancelation
Our latest audio utility leverages a massive deep-learning database to reduce background noise from the microphone* and incoming audio. Distracting keyboard clatter, mouse clicks and other ambient noises are smartly pared back so you can hear and be heard with crystal clarity while gaming or in calls.
Multiple port connection supported:
It supports all types of audio device connected, e.g, 3.5mm audio jack, USB, or Bluetooth.
How to support Two-Way AI Noise-Cancelation?
You can check the product specifications on the ASUS official website.
(Ex: ROG MAXIMUX XIII EXTREME)
Two-Way AI Noise Cancelation: Setup Guide
1. Support List
2. Setup Guide
3. Test Two-Way AI Noise Cancelation
1. Support List
Platform |
Chipset |
Model List |
Intel |
Z590 |
ROG MAXIMUS XIII EXTREME GLACIAL |
ROG MAXIMUX XIII EXTREME |
ROG MAXIMUX XIII HERO |
ROG STRIX Z590-E GAMING WIFI |
ROG STRIX Z590-F GAMING WIFI |
ROG STRIX Z590-A GAMING WIFI |
ROG STRIX Z590-I GAMING WIFI |
TUF GAMING Z590-PLUS WIFI |
TUF GAMING Z590-PLUS |
PRIME Z590-A |
H570 |
TUF GAMING H570-PRO WIFI |
TUF GAMING H570-PRO |
B560 |
ROG STRIX B560-A GAMING WIFI |
ROG STRIX B560-F GAMING WIFI |
ROG STRIX B560-G GAMING WIFI |
ROG STRIX B560-I GAMING WIFI |
TUF GAMING B560-PLUS WIFI |
TUF GAMING B560M-PLUS WIFI |
TUF GAMING B560M-PLUS |
AMD |
X570 |
ROG CROSSHAIR VIII DARK HERO |
TUF GAMING X570-PRO (WI-FI) |
B550 |
ROG STRIX B550-XE GAMING WIFI |
ROG STRIX B550-E GAMING |
ROG STRIX B550-F GAMING (WI-FI) |
ROG STRIX B550-F GAMING |
ROG STRIX B550-A GAMING |
ROG STRIX B550-I GAMING |
TUF GAMING B550-PLUS (WI-FI) |
TUF GAMING B550-PLUS |
TUF GAMING B550M-PLUS (WI-FI) |
TUF GAMING B550M-PLUS |
TUF GAMING B550M-ZAKU (WI-FI) |
TUF GAMING B550-PRO |
B450 |
ROG STRIX B450-F GAMING II |
TUF GAMING B450M-PRO S |
TUF GAMING B450-PLUS II |
TUF GAMING B450M-PRO II |
TUF GAMING B450M-PLUS II |
2._Setup Guide
Step 1. Open and Enter Armoury Crate
Step 2. Click “Device” and choose your motherboard.
Step 3. Click “Audio”
Step 4. Turn on Microphone input /Audio output after plugging in the audio device and select the device to which you want to apply Microphone input /Audio output
Step 5. Adjust the Microphone input /Audio output level, depending on the environment you are in.
* For the suggested Noise Type, please refer to the table below.
Level |
User scenario |
Noise Type |
Low level |
Slightly disturbed by the background noise during the call |
e.g. Keyboard typing, Mouse clicking, Fan sound, Talking sound in the office etc. |
Middle level |
Interference caused by background noise during the call. User needs to repeat for clear conversation |
e.g. Sound of kids playing , Chit-chatting, Background noise in a cafe |
High level |
Can't hear your voice during the call. The noise has seriously interfered the call. |
e.g. Construction works, House renovation, Vacuuming floor, etc. |
Step 6. Continue to set up for the communication or Live streaming apps.
Note:
1. Click “Reset” when you re-plug and change audio device, or when your device is not detected.
2. Click “OK” to continue
2._TEST Two-Way AI Noise Cancelation
To test whether unwanted background noise from your microphone or incoming audio is removed with this function turned on, we recommend to confirm by the following steps:
· Audio output test
1. Enable Audio Output and select your output speaker device (Ex:3.5mm->Realtek USB Audio)
2. Open communication software (Ex:Teams,Discord,Zoom,etc.), and select output device “AI Noise-Canceling Speaker (ASUS Utility)
3. Have one person play the background noise and speaking at the same time; while another person testing if the voice received is clear and without any environmental sound in a different spacing without any interference with the first person.
· Microphone Input
1. Open the audio recording app when the Microphone Input is disabled. Take Window’s Voice Recorder as example, and record your voice with your microphone. Click on the ”Record” icon to start the recording.
2. Setup Two-Way AI Noise Cancelation in Armoury Crate (Please refer to the Instruction above).
3. Setup Two-Way AI Noise Canceling Microphone(ASUS Utility) in the Sound Settings of Windows.(Please refer to Instruction below)
Step 1. Click “Open Sound Settings”
Step 2. Select “AI Noise Canceling (ASUS Utility) in Input
4. Open the audio recording app again and record your voice with your microphone. You can compare the difference to check whether Audio Output is enabled.
