FAQBot
Community Admin
Community Admin
[Motherboard] GameFirst VI - Introduction
1. GameFirst VI introduction
2. Models Supported
3. GameFirst VI Install& Uninstall
4. GameFirst VI Dashboard
5. GameFirst VI Network Monitor
6. GameFirst VI Network Analyzer
7. GameFirst VI Smart Router
8. GameFirst VI Settings
9. Q&A
GameFirst VI is an integrated network tool, designed for ASUS ROG products for network optimization. It can effectively reduce network delay, minimize in-game lag, and also create the best network environment for players.
2. Models Supported
How to confirm whether my motherboard supports GameFirst VI?
Please go to ASUS Official Website:https://www.asus.com/
1. Click the magnifying glass icon
2.  Enter the motherboard model in the Search Bar
3.  Click the motherboard model shown below (EX:ROG MAXIMUS XII EXTREME)
4. Click (specifications)  ->  (Software features)
How to obtain and install GameFirst VI , please follow :
Download ASUS GameFirst VI
You can get the latest software, manuals, drivers and firmware at the ASUS Download Center. ASUS ASUS download center :
If you need more information about ASUS Download Center, please refer to this LINK :
* How to check product model : https://www.asus.com/tw/support/Article/565/
1. ASUS download center Enter a model name or select a product to find drivers, manuals, warranty information and more.
Please enter a model name -> Select ”Driver & Utility
(Ex: ROG MAXIMUS XII EXTREME)
2.Select” Driver & Utility -> Please choose OS version
3. Click (Utilities) -> Find “ GameFirst VI”to download  (Recommended to use the latest version)
--> How to remove the software, please refer to LINK
4-1 How to start GameFirst VI
Please type and search [GameFirst VI] ① in the Windows Search Box, and then click on [Open] ②
4-2 Dashboard
System resources ①: It includes Network Smoothness, CPU Usage, Upload and Download display
Profile Option ②: User can select Profiles they would like to apply such as: Gaming First, Live Streaming First, Multimedia First or Adaptive Intelligence
* For Profiles setting, please refer to 8-3 Profiles
Application categories and status ③: You can check Application Categories and the Network Status in the page. See the list below for details of each item.
ItemNameImage Description
A      Application group   To define application categories,for example Game、Live stream、Multimedia、Web、File transfer and Others
BSpeed Speed To switch the network traffic priority for application (For example Extreme/ High/ Medium/ Low)
C ApplicationApplication’s name
D
Download/Upload          speedTo display Download/Upload speed
EDefault networkTo assign network connection for each application,for example WiFi or Ethernet connection
FBlock trafficTo disable application network connection
GClose applicationTo close application
HOptionsTo select application group,speed priority、bandwidth control and block traffic,as shown below
For icons ① to ③ icons, please refer to the description from sections H-1 to H-3.
H-1 Group①: Defines the application categories: Game, Live stream, Multimedia, Web, File transfer and Others
H-2 Block traffic②: Disables the application network connection
H-3 Enable Application policy③
       Speed: To switch the network traffic priority for application (Example Extreme/ High/ Medium/ Low)
       Enable bandwidth control: To control application bandwidth rate-limiting
Back to Contents
5-1 Top 5 Apps②: Monitors network usage for Top 5 Apps or group
5-2 Group traffic ③: Monitors network upload/download speed in real time by group
5-3 Network traffic ④: Monitors the real time data for upload or download rate
Back to Contents
6. GameFirst VI Network Analyzer①
6-1 Network Information②: Reviews gateway information and status. (Example: Status, Speed, Physical address, IPv4 Address ,IPv6 Address, Subnet Mask and Default Gateway)
6-2 Wi-Fi Quick Assist ③: Analyzes the available wireless signals and the signal strength. Also, views the current WiFi connection, channel and the number of shared connections.
Back to Contents
Discover ASUS ROG router with ASUS ROG First which accelerates the networking packets of your system so that you can enjoy a faster and smoother networking experience.
For icons ② to ⑤ , please refer to the details in the list below :
Item Name Image Description
②        DiscoverDiscover ASUS ROG router whether is with ASUS ROG First function
Router Log-In        Log-in the router you connected
Wi-Wi ChannelViewing the current WiFi connection, the channel and the number of shared connections available wireless signals and the signal strength
Game BoostTurn on Game Boost
Back to Contents
8. GameFirst VI Settings①
8-1 Game Turbo②
For icons ③ to ⑦ , please refer to the details in the list below:
Foreground AccelerationAutomatically accelerate the foreground application
Show Booster NotificationsPop-up boater notification window when launching games
Auto-Close Booster NotificationsAutomatically close the booster notification window after 5 seconds
Booster Download SpeedAdjusting TCP/IP window flow size to help optimize the rate which data is transferred between replication log server hosts
Extreme Upload for Lower LatencyEnable TCP_Nodelay on intensive applications for lower latency
8-2 General①
For ② to ⑥ icons, please refer to the details in the list below :
ItemNameImageDescription
Automatically launch on startupAutomatically launch GameFirst VI while startup
Pop up window to show closing option      While closing GameFirst VI, a notification window will pop up for choosing to close or minimize program
Use the latest profileUsing the last profile after restart GameFirst VI
LanguageLanguage selection (GameFirst VI will restart after apply new language)
ResetReset all applications policies/ profiles policies/ general settings
8-3 Profiles①
User can define each application categories (for example Game,Live stream,Multimedia,Web, File transfer and Others) , speed priority and enable bandwidth control.
For ② to ④ icons, please refer to the details in the list below:
Profiles②: User can select Profiles they would like to modify, for example Gaming First、Live Streaming First、Multimedia First or Adaptive Intelligence
Speed③: To switch the network traffic priority for application (For example Extreme/ High/ Medium/ Low)
Enable Application policy④: To control application bandwidth rate-limiting
8-4 About①: To confirm Gaming First VI current version, and [Check for updates] ② for upgrading
9. Q&A
Q1: What are the new features in GameFirst VI?
A1:  *UI optimization
*Adding AI Adaptive Intelligence Profile
*Adding rule setting by each application
*Adding TCP packet acceleration related application
*Provides IP geolocation, server locations and ping value for each application
*Auto-Switch to High Performance during games
*Able to close an application in GameFirst VI
Q2: How to confirm my network connection status?
A2: The connection status will be as shown below:
 No connected
 Connected,only Intranet
 Connected with Internet
Q3: Does my router support ROG First function?
A3: If your router doesn’t support ROG First function, you will see the page below while clicking [Smart Router] ①,and [Discover]②
* For router models with ROG First supported, please refer to ASUS official website
Version history
Last update:
‎04-11-2025 12:15 AM
Updated by:
