on 04-12-2025 10:11 AM
[Motherboard] Armoury Crate V.6 interface Power saving removal changes, how to adjust Power saving settings
Directory:
1. Optimize CPU power limit for power saving: It can be set in the BIOS
2. Turn off OLED display: (OLED display light calibration setting) can be set in Armoury crate
3. Set Aura Sync lighting effect to Dark: This can be set in Armoury crate
4. Set Fan Profile to Silent Mode: This can be adjusted within Armoury crate
5. Enable Windows Power saver plan Go to Settings: Set it in the Windows console
6. Q&A,
Originally Power saving option location
The following items can be set for the original power saving
Example: ROG MAXIMUS Z890 APEX;
1.Optimize CPU power limit for power saving: (CPU Power optimizes energy saving); Options can be adjusted within the BIOS
Intel's path: Ai tweaker > Internal CPU Power Management > Short Duration Package Power limit > It is recommended to set Auto
AMD's path: Ai tweaker > Precision Boost Overdrive > Precision Boost Overdrive(Manual) > PPT Limit > Auto is recommended
2.Turn off OLED display: (OLED display light calibration setting) can be adjusted in Armoury crate (*Please refer to whether this model can be supported)
Devices->setting
->Hardware Monitor
When system is in working state :on/off)
When system is in sleep, hibernate or soft off states: on/off
Rotate the OLED display contents 180 degrees: 180 degrees
3.Set Aura Sync lighting effect to Dark: This can be adjusted within Armoury crate
Aure Sync - > Aura effects - > Dark(off)
4.Set Fan Profile to Silent Mode: Can be adjusted within Armoury crate
Dashboard ->Fan mode
5.Enable Windows Power saver plan: Adjust in the console
Control panel->Hardware and Sound->Power Options
Q&A
Q1.Do you support Armoury Crate?
[ASUS Armoury Crate] Armoury Crate Compatible Devices
Q2.How can I check the Armoury crate version?
A2. Settings->About
Through the settings page, click "About", you can check the current version of Armoury Crate, or if necessary, open the APP diagnosis, the system will start to record logs, and click the right button to generate log files.
