a month ago
[Motherboard] Armoury Crate: Control CORSAIR RGB DRAM Lighting
Armoury Crate supports Aura Sync lighting control for a wide range of third-party devices. Most Aura Sync-compatible models can directly download the required lighting package through Armoury Crate. If you are using a CORSAIR device, please follow the steps below to install the dedicated CORSAIR package. Once installed, you can control the lighting effects directly in Armoury Crate.
Steps to Enable Armoury Crate Control of CORSAIR RGB DRAM
To enable Armoury Crate to detect and control your CORSAIR RGB DRAM lighting, please complete the following steps:
1. Install and update Armoury Crate software to the latest version
Armoury Crate - Support
2. Install "CORSAIR RGB Memory Plugin for ASUS AURA SYNC": Download and install the plugin from CORSAIR Downloads | CORSAIR iCUE Software
After completing these steps and restarting the PC, you can control and synchronize your CORSAIR RGB DRAM lighting through Armoury Crate.
*Note: If your CORSAIR devices cannot sync with Aura Sync lighting or are not detected, please contact CORSAIR support directly for assistance.
