FAQBot
Community Admin
Community Admin
[LCD Monitor] ROG OLED Gaming Monitor Pixel cleaning process.
There are three main methods for pixel cleaning:
1.Manual cleaning: Through the OSD, perform the following operations: System Setup -> Pixel Cleaning -> Pixel Cleaning ->  ON.
During the cleaning process, the screen will display a completely black image, and the indicator light will flash yellow continuously. Once the cleaning is completed, the screen will automatically light up, and the indicator light will turn solid red.
2.Automatic cleaning in standby mode: When the power indicator light is on, after entering standby mode for five minutes, the ROG Logo will flash five times and then start the pixel cleaning process, which lasts about 5-6 minutes. Upon completion, the ROG Logo will flash five times again.
3.Manually turning off the display without cutting off the power: In this state, pixel cleaning will still be executed, but there will be no display or indicator lights.
ASUS recommends that users perform pixel cleaning regularly to ensure that the OLED display maintains optimal condition.
Comments
codex174
You could run the monitor’s pixel cleaning feature to see if it clears the stuck pixel.
If it doesn’t change after that, it’s probably permanent and worth checking with support.
Version history
Last update:
‎04-09-2025 06:58 PM
Updated by:
