on 10-25-2025 10:00 AM
[LCD Monitor]If your LCD monitor appears no image or abnormal display after connecting to the monitor's SDI port, please follow this FAQ
please verify that the signal format being used is correct:
1. PA24US only support Level A signal(not support Level B).
Incorrect signal settings may cause transmission failure.
If a Level B signal is mistakenly interpreted by a Level A receiver,
the image may appear split or distorted.
2. Please confirm whether the signal format used is in the following list:
If still have problem,please follow below FAQ:
[LCD Monitor] Troubleshooting - No display after turning monitor ON
