FAQBot
Community Admin
Community Admin
[LCD Monitor]How to set up ASUS Power Sync with an ASUS NUC and a compatible monitor
 To provide you more detailed instruction, you can also click ASUS YouTube video link below to know more about
ASUS Power Sync: How to Set Up for ASUS Monitor and NUC PC via MyASUS software | ASUS SUPPORT - YouT...
ASUS NUC mini-PCs set a new benchmark for performance and versatility in ultracompact form factors. ASUS Power Sync, a feature available with a broad range of ASUS NUCs, synchronizes the power buttons for an ASUS NUC and a connected compatible monitor, allowing both devices to be turned on or off with the press of a single button. This eliminates cable clutter for a more organized, efficient, and visually appealing setup, and it also allows deployment of PC setups in scenarios where the power button of either the NUC or monitor is not easily accessible.
How ASUS Power Sync works
ASUS Power Sync is a feature that allows HDMI-connected devices, like an ASUS NUC, to communicate control signals with your monitor. When connected, you can turn the device on or off simultaneously with the monitor.
The functionality of ASUS Power Sync is customizable through the MyASUS app. One common usage scenario occurs when the ASUS NUC is powered on and connected to the monitor. WHen you turn off the monitor, the connected ASUS NUC will also turn off:
Similarly, when the ASUS NUC is powered off and connected to the monitor, when you turn on the monitor the connected ASUS NUC will power up.
Follow these steps to set up ASUS Power Sync:
1.Checking Hardware Compatibility: Ensure you have a compatible ASUS NUC (e.g., NUC 11, NUC 12, or other models supporting ASUS power sync) and (via HDMI CEC). A list of compatible devices can be found at the end of this guide.
2.Connect Cables: Connect your ASUS NUC to the monitor using an HDMI cable (version 1.2 or higher). Make sure all other required cables (power, keyboard, mouse, etc.) are properly connected.
3. BIOS settings of NUC: HDMI CEC: Enable or disable the HDMI CEC function. To activate this function, you can connect the device to the monitor through the HDMI port.
• BIOS set up instruction for ASUS NUC:
• BIOS set up instruction for ASUS Mini PC:
4.Adjust Monitor Settings: Check your monitor’s on-screen display (OSD) menu. Navigate to System Setup and enable the ASUS Power Sync (or HDMI CEC) function.
5.Enable ASUS Power Sync in the MyASUS app: Launch the "MyASUS" software on your ASUS NUC. Click on the "My ASUS Devices" button located on the left side. In the "Display" tab, make sure the targeting monitor model name exists in the dropdown menu and jump to Power Sync Control section. Enable Power Sync Control" and any sub-items that fit your preferences. When enabled, the toggle button will turn blue, indicating the feature is active.
6. Adjust the Power Button Settings in Windows: Open the "Control Panel" and select "Power Options." Click on "Choose what the power buttons do" located on the top-left side. Select “Shut down” from the power button setting. This will define the action triggered by the monitor’s power button when using ASUS Power Sync.
Supported ASUS Monitors
Please refer to the specifications of the product model on the ASUS official website: Features (Features: ASUS Power Sync: Yes)
Supported ASUS NUCs
Model namePower Sync Without MyASUSPower Sync With MyASUS
NUC 12 Pro
NUC 13 Pro
NUC 13 Rugged
NUC 14 Essential
NUC 14 Pro
NUC 14 Pro+
NUC 14 Pro AI2025Q3
NUC 14 Pro AI+2025Q3
NUC 14 Performance
ROG NUC
NUC 15 Pro
NUC 15 Pro+
ROG NUC (2025)
NUC 15 Performance
Please note the following regarding the compatibility of ASUS power sync with ASUS monitors:
1.This feature can be enabled in the system settings.
2.The list of supported models may be updated periodically. For a complete and up-to-date list of compatible monitors, please refer to the official ASUS website or product documentation.
3.Power Sync is currently supported only in PC Shutdown Mode. This means that the monitor will enter the "Off" state only when the PC shuts down. (In other words, if the PC enters Sleep Mode, the monitor will not automatically turn off.)
Streamline and declutter your ASUS NUC setup today with ASUS Power Sync
Using ASUS Power Sync makes it easier than ever to create a clean, efficient, and high-performance workspace. The combination of ASUS NUC and a monitor compatible with ASUS Power Sync unlocks the full potential of your devices, bringing more organization and productivity to your day. If you're ready to streamline your workspace and boost productivity, consider integrating ASUS Power Sync into your setup today.
Version history
Last update:
‎10-07-2025 07:46 PM
Updated by:
