on 11-29-2025 09:00 AM
[LCD Monitor]ASUS Virtual Screen feature
To provide you more detailed instruction, you can also click ASUS Youtube video link below to know more about How to Use Virtual Screen on Your Ultrawide Gaming Monitor
The ASUS Virtual Screen feature allows windows system to recognize one monitor as two independent display so you can create a virtual display with 1:1, 2:1 or 1:2 formats. With this you can use single source* to open two windows at the same time with ease, enjoy your gameplay or YouTube video in a fixed 16:9 window without black bars while use another chat room or streaming APP as an independent display at the same time.
*For DisplayPort or USB Type-C connections only.
How to check if your monitor supports the dual-mode (hotkey) function: Visit the ASUS official website and review the product specifications.
(Example: ROG Strix OLED XG34WCDG)
How to set up:
Enter the OSD menu and enable Virtual Screen.
①Syatem Setuo->②Virtual Screen->③Choose 1:1 or 2:1 or 1:2
1:1
2:1
1:2
Questions and Answers:
Questions 1:Some systems might retain their original display resolution. If this happens, simply go to your display settings and switch to the recommended resolution
Answers 1:
Click on the screen you need to adjust, 1 or 2.
Just select the recommended resolution.
